Land03342.pngSelecting the plant data source
Command
Workspace: Path
Choose Plant Data Source
Design Suite: AEC > Plants
Landmark: Landmark
Context menu
Plant names, botanical information, and other plant data that is used for the plants in the drawing can come from one of two locations, as described in Concept: Plant style and plant data integration. The Choose Plant Data Source command selects the preferred source of plant data when working with plants in Landmark and specifies whether the data source is updated when the plant style changes.
To select a plant data source:
Select the command.
The Choose Plant Data Source dialog box opens.
Parameter
Description
Plant data source
Select either Plant Catalog or Vectorworks Plant Database
Plant Catalog
Explore
By default, the user folder location is used for plant catalogs, but this location can be changed by clicking Explore
Update the Plant catalog with Vectorworks Plant style changes
Any changes made to the plant style are automatically updated in the associated plant catalog, except for online catalogs, which cannot be updated. When this option is deselected, plant style changes do not affect the catalog data.
User Folder
Indicates where the plant database information is to be located. By default, the plant database is stored locally, in the user folder.
Workgroup Folders
Larger offices that wish to share the plant database among several computers can store and access the plant database from a workgroup folder located on a central computer or server. Alternatively, select Browse for database folder and then click Browse to specify the desired location.
Update the Plant Database with Vectorworks Plant Style Changes
Any changes made to the plant style are automatically updated in the associated plant database. When this option is deselected, plant style changes do not affect the plant database.
This choice applies when accessing plant data in all Landmark features.
Updating plant data from Vectorworks
Command
Workspace: Path
Update Plant Data
Landmark: Landmark
The plant catalog or plant database records can be updated from associated plant style data. Normally, this occurs automatically (unless the Update the Plant catalog with Vectorworks Plant style changes / Update the Plant Database with Vectorworks Plant style changes option is deselected in the Choose Plant Data Source dialog box). This command manually updates the catalog or database records, which is useful when the option is deselected.
Online plant catalogs cannot be updated.
To update plant data manually:
Select the command.
All plant styles in the current file are compared to plant names in the plant catalogs or plant records in the plant database, and matches are updated automatically. The plant’s botanical (Latin) name is used to determine the match.
If no match is found, the Update Plant Catalog and Database dialog box opens, listing plant styles that don’t have a match.
Mark the plant styles to add by placing a check mark in the Insert column. Select the plant catalog to update with the marked plant styles by choosing it from the Insert in Plant catalog list.
Updating plant styles with plant data
Command
Workspace: Path
Update Vectorworks Plant Styles
Landmark: Landmark
All plant styles in the current document can be updated automatically from the plant catalog or plant database.
To update plant styles:
Select the command.
All plant styles in the current file are compared to the plant catalogs or plant database, and matching records are updated. The plant’s botanical (Latin) name is used to determine the match.
If no match is found for a plant style, the Update Vectorworks Plant Styles dialog box opens, listing the plant styles that were not updated for your information.
Creating plant styles
Using plant catalogs
The plant database
